Hydraulic noise on L3710
   / Hydraulic noise on L3710 #1
PAFarmBoy
Pennsylvania
Kubota L 3710
When I fully raise my rear blade on my tractor, it sounds like the engine is straining. If I then lower the blade a very small amount, the engine returns to normal.
Any thoughts/suggestions would be appreciated!
/forums/images/graemlins/confused.gif
   / Hydraulic noise on L3710 #2
Linkage that controls the hydraulics needs to be adjusted to stop trying to raise 3PH when it is at end of it's up stroke. There is a thread that I could not find on how to make this adjustment on a B2910. I'm not sure if the L3710 is the same.
Until you get the adjustment made make sure you keep the 3PH a little below full up. Hydraulic oil will over heat and cause damage to hydraulic system if kept in position you describe.
Thanks very much for the update !
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
Diesel Forklift (A51691)
Diesel Forklift...
2006 Ford Expedition 4x4 SUV (A50324)
2006 Ford...
ITEM LOCATION (A53084)
