Hydraulic noise on L3710
   / Hydraulic noise on L3710 #1
PAFarmBoy
Pennsylvania
Kubota L 3710
When I fully raise my rear blade on my tractor, it sounds like the engine is straining. If I then lower the blade a very small amount, the engine returns to normal.
Any thoughts/suggestions would be appreciated!
/forums/images/graemlins/confused.gif
   / Hydraulic noise on L3710 #2
Linkage that controls the hydraulics needs to be adjusted to stop trying to raise 3PH when it is at end of it's up stroke. There is a thread that I could not find on how to make this adjustment on a B2910. I'm not sure if the L3710 is the same.
Until you get the adjustment made make sure you keep the 3PH a little below full up. Hydraulic oil will over heat and cause damage to hydraulic system if kept in position you describe.
Thanks very much for the update !
2007 Pace American Enclosed Trailer (A49461)
2007 Pace American...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
