Hydraulic newbie
/ Hydraulic newbie #1
Spitfirefd
Soquel
2011 Kubota B3200hsd
So I have been poking around on the forum here for a while and there are many posts that seem to speak to part of my question but I guess I need it spelled out to me so, here it goes.....
I have a 2011 Kubota B3200 with the LA504 loader and I want to add a 3rd function valve for a future 4 in 1 bucket. I also want to add a top n tilt kit to it.
1 can both be added?
2. What is the cheapest way to do it?
3. I would like to do as much of the install myself as I can.
What are the best online parts shops?
I know that there are a lot of questions so any help would be appreciated.
Thanks in advance.
Jay
/ Hydraulic newbie
I don't have anything yet. I think I should start with the top n tilt 1st before the 3rd function on the front though.
Jay
/ Hydraulic newbie #4
The third function is probably easier and cheaper than rear remotes though both are not really difficult. I was a hydraulic n00b 3 months ago but after tapping in to my hydraulics and adding 2 sets to my tractor it all seems pretty basic now. There is a lot of great information here about adding both if you search for it and read a bit you'll find how others have done it and be able to decide on a type that will work best for you. I've run hoses from the rear remotes to my loader to run the third function for now but plan on adding a diverter to the curl circuit soon for it as it will be much better and then I can have tilt cylinder with the hydraulic top link.
Valves solenoids, cylinders and diverters from surpluscenter.com are priced pretty good and several types, there's a few online stores for fittings with a good selection but sometimes it's easier if you can get them locally.
That should give you a start, good luck.
Aux. hydraulic outlets should be standard on all tractors IMHO..
(4) New Caterpillar Skidsteer Loader Tires (A66408)
(4) New...
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
Conveyor (A64194)
Conveyor (A64194)
Steel Coils (A65640)
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
213141 (A64276)
213141 (A64276)
