Hydraulic motor Spool valve & Flow Control valve
/ Hydraulic motor Spool valve & Flow Control valve #1
bigdan65
John Deere 4500 & 770
I am adding front hydraulics to run a hydraulic motor. The motor cannot use the full flow of the tractor. I want to put the Flow Control before the Motor Control valve so I can reverse flow at the controlled rate. The motor spool valve will be the last valve in system. Can I Tee the EX flow of FC valve and T tank port of Motor spool valve?
/ Hydraulic motor Spool valve & Flow Control valve #2
Yes you can tee the excess flow into return from the motor directional control valve.
/ Hydraulic motor Spool valve & Flow Control valve #3
No problem doing what you have drawn.
There are a number of factors that effect flow. Losses from valves, fittings, lines and hoses adds up. Used a 12gpm hydraulic motor for a FEL pole chainsaw on a 16gpm 3rd function tractor. Intermittent use, usually near idle. So far no trouble even with occasional dead heading from stalled motor. Commercially made similar saws use smaller motors for over a wide range of tractors flow capacities.
Adding 36’ of hose and fittings reduces available flow. Used 1/2” hose to reduce loss. Use a small metering flow control valve at the motor to provide a drop of fluid every 10 seconds to the saw chain for lubrication.
Use same saw on a 7gpm 3rd function tractor with little difference in function.
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A60430)
25' SINGLE AXLE...
206707 (A58375)
206707 (A58375)
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A60429)
2023 HANGCHA...
26120 (A56859)
26120 (A56859)
