Hydraulic motor sizing - weird project
   / Hydraulic motor sizing - weird project #41
the very simplest control system for travel drives is closed loop hydrostatic drives. These provide forward reverse direction, braking, steering without any external valves and have option of proportional displacement control so they could be operated via wired pendant that you bring in the car or potentially a wireless remote control.
Basically a newer skid steer system since a good portion of these are now electro proportional control via a joy stick.
Thanks, that sounds great. A quick search hasn't gotten me much closer to understanding what components are needed to make such a thing. A complete plug and play system would be ideal, but probably way over my budget - even if such a thing is available
   / Hydraulic motor sizing - weird project #45
cmaas,
Have you established or determine what size drive motors you will be using for the wheels? With this information we could then figure required pump flow and pressure to achieve desired torque and speed. From this information you could then start looking for pumps. Are there any repair centers for fishing trawlers in your area? The might have some pumps and motors used for winches but no clue if electrical - proportional control or manual control used on fishing trawlers.
Two major manufacturers of hydrostatic pumps are Sauer Danfoss and Rexroth. Both of these companies should have pumps that would fit in your application.
Eaton & Parker are two other companies but not sure if they would have hydrostatic pumps in the size that you are looking for.
cmaas,
Thank you for that. I really appreciate your taking the time to advise me.
I like the idea of using hydrostatic drive, but, unless I am not understanding it right, I would need a hydrostatic pump for each wheel and a gear pump for the five wheel and ramp lifting cylinders. I'm pretty sure that will be too pricey for this hobby project. Especially since it has a good chance of being a failure.
I have two 28 cu. in. wheel motors now and I need about 600ft. lb. of torque per wheel to get me up my steepest hill. It's okay if I crawl up that hill at 2mph - the hill is very short.
Here is what I'm thinking might work, leaving out the minor details, like braking, for now:
- 2 28cu. in. wheel motors.
- 1 3.11 cu. in. gear pump. Belt driven w/electric clutch.
- 2 one spool directional motor control valve w/ flow control (It looks like a solenoid controlled valve would be too expensive, though I haven't actually found one yet).
- 1 proportional flow divider.
Any thoughts?
   / Hydraulic motor sizing - weird project #47
Cmaas
Yes those components will work
Question need for flow control on motor valves if you have a flow divider feeding them or did you mean a motor valve with good feathering for fine flow control for slow movement, steering, etc.
for braking look at dual counterbalance valves. These are designed to prevent runaway operations and typically work well. Size them as close as possible to full flow through the motor to large a valve and they do not control as well
sun hydraulics is the most common source for counterbalance valves in USA.
Rexroth - Oil Control is another source but as not as popular in the USA.
   / Hydraulic motor sizing - weird project #48
Any thoughts?
I have an all hydraulic machine. It has one wheel motor on each corner. There's one variable volume pump that drives two wheel circuits (right front is in series with left rear, left front is in series with right rear, then both of those circuits are in parallel). All 4 wheel motors get the same flow and steering is accomplished by articulation. So you could drive two wheel motors with one pump. That would control speed and direction. I'm not sure how you'd vary the flow to each wheel motor for turning. And yes, you'd need a gear pump for the cylinders.
They make the variable volume pump with one, two or more gear pumps piggybacked on to the VVP. That way only 1 driveshaft is required.
Cmaas
I took flow control to mean variable speed control. It seems like without that motor directional valves are either on or off. Is that wrong? There are a lot more available valves if I'm not looking for the words "flow control".
"A little bit of knowledge is a dangerous thing". Designing hydraulic systems is just what that saying applies to. I read a bit here and a bit there. Often it seems like different terms are used for the same component. The latest thing I read tells me I should use "meter in flow controls". That way I don't need a case drain in the motor. Which my motors don't have.
I am thinking that with a pump that has a 35GPM max that each motor valve will only see 17.5 GPM so a valve that has a 18GPM capacity should work. My motors have a 23.7GPM max.
Sun Hydraulics want me to choose a "pilot ratio" for the counter balance valve. Any thoughts about that?
I guess it's a good thing that this barge is going to be slow. Otherwise this could all be pretty scary.
Thanks again for the help.
That's interesting. I'm just starting to understand how the system I've got in mind is going to work so trying to figure out something like yours is making me a little crazy. I guess I could make my back wheels steer if I really wanted to but I'm not sure how the front drive wheels would do without a differential.
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
Forklift (A59228)
Forklift (A59228)
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
