Hydraulic motor on rear blade
   / Hydraulic motor on rear blade #21
Another option would be to use a hydraulic rotary actuator. They are made to have much more torque than motors and provide a controllable rotation. Most do not have 360 degree rotation. To get the torque you need you would most likely need a double rack unit.
A planetary final drive would probably work also. Any equipment salvage yards around you?
   / Hydraulic motor on rear blade #22
Interesting ideas, I use my blade going forward and backing up quite often. I do have hydraulic angle and tilt with an option for hydraulic offsett.
When I rotate my blade 180 I have to unpin my angle cylinder spin the blade the 180 and repin the angle cylinder.
   / Hydraulic motor on rear blade #23
Torque definitaly an issue with just a direct drive motor setup.
It CAN be made to work with many of the ideas mentioned here.....but whats the budget for this project?
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
