Johnkn
Platinum Member
Hi, I recently had a LandPride grapple installed on my new tractor. Among other things, the lines from the couplers mounted on the FEL and going to the grapple were too long. Today I had them shortened 12" but now have another issue. Unfortunately I didn't even think about this, but when the shop crimped on the new 45* fittings they ended up pointing almost 180 degrees from where there need to be. Obviously I can move the 45* connectors a little, 3-4 o'clock position etc. , however the fittings face up vs down before connection now and when I connect them they are under a lot of twist. See the overall pic below, the lines won't lay together because they are being twisted and are under tension. Other than cutting them off and starting over, is there any type of swivel I can put between the grapple fitting the hoses that will allow the hose to twist radially? Or are there new 45* fittings I can have crimped on that also have a radial swivel? thanks
