Hydraulic Line Swivel?
/ Hydraulic Line Swivel? #1
Johnkn
Laplata, MD
Kubota LX3310
Hi, I recently had a LandPride grapple installed on my new tractor. Among other things, the lines from the couplers mounted on the FEL and going to the grapple were too long. Today I had them shortened 12" but now have another issue. Unfortunately I didn't even think about this, but when the shop crimped on the new 45* fittings they ended up pointing almost 180 degrees from where there need to be. Obviously I can move the 45* connectors a little, 3-4 o'clock position etc. , however the fittings face up vs down before connection now and when I connect them they are under a lot of twist. See the overall pic below, the lines won't lay together because they are being twisted and are under tension. Other than cutting them off and starting over, is there any type of swivel I can put between the grapple fitting the hoses that will allow the hose to twist radially? Or are there new 45* fittings I can have crimped on that also have a radial swivel? thanks
/ Hydraulic Line Swivel? #2
That can be a tricky situation. You do need plenty of slack, especially for full rotation (or dump) with the loader all the way up. Live swivels (swivels under pressure) are pretty pricy and I'm not sure if they would "twist" under pressure before your lines do as pictured, weakest link type of thing. If both lines would lay like the one on the right that would be perfect. It liiks like JIC fittings on the grapple and they will tighten with your line in any position and If JIC, just play with the one line to "clock" it around so they lay together.
The position of the loader up or down has no bearing on this. This is a concern between the couplers mounted to the FEL and the grapple. The pics show the grapple fully curled under and extended,. I still have plenty of service loop in the hoses even after having 12" removed. The issue is that the hoses are twisted radially now. if I remove the bottom fittings to the grapple, the 45* connectors pop straight up (or more) and I have to twist them down to make the connection pulling a lot of tension on everything. thanks
/ Hydraulic Line Swivel? #4
The problem as i see it is more at the other end. Had they used a straight fitting on the hose and a 90 degree fitting to the QD you could clock the hose / elbow connection any way needed to make the hose and 45 degree fitting lay right. I always avoid making hoses with two angled crimp fittings. There is simply no forgiveness.
/ Hydraulic Line Swivel? #5
I think the 90 degree fittings on couplers are wrong. Replace with 90's that have female swivels for hose connections.
I don't disagree, the problem is that where they welded the mounting tab to the FEL tube puts the connectors fairly close to the grapple when it's rolled all the way back. Replacing the 90* fitting with straight, the hoses would likely contact the grapple at that point with the grapple rolled back, so I'm trying to keep the 90*. I believe I still have enough service loop to cut the 45* connectors off and install a 2-way swivel if there is one, like this:
In its present configuration it needs a radial swivel on one of the ends to relieve the tension.
It's going to feel really good when the beating stops on this new tractor...
Those 90's connectors do swivel, right now that are pointing to ~4 o'clock but easily move .
I hate to introduce additional points of failure, but even an in-line swivel on each hose would work, if there is one. thanks all
/ Hydraulic Line Swivel? #9
I did not suggest removing the 90s. I said the hose should have a straight fitting crimped on and a separate 90 degree fitting be used to attach the QD to the hose. That will allow you to clock the hoses so they lay flat and together when tpyour 45 degree fittings are oriented the way you need them. I would not put swivels where you indicate. They provide no advantage.
Gotcha, even better would be a straight swivel fitting crimped on to the hose attaching to the separate 90* fitting at the QD. thank you......
/ Hydraulic Line Swivel? #11
You can turn the fittings. Grab the ferrule in a vice or with a pipe wrench and grab the collar with another pipe wrench and turn away, the fitting will turn in the hose...........Mike
/ Hydraulic Line Swivel? #12
Yeah, but that will not make the hoses lay flat together. The issue is the angled fittings on each end of the two hoses are not crimped at the same number of degrees from one another. One hose is clocked differently than the other.
/ Hydraulic Line Swivel? #13
I'm being thick here LOL so forgive me :).
So why can't the crimped hose ends be turned on the hose crimp to wherever they fit good or am I being really thick headed which is a very good possibility .............Mike
/ Hydraulic Line Swivel? #14
You are correct Mike. Those may be different but all of mine can be turned at the ferrule.
/ Hydraulic Line Swivel? #15
I just went through all of this putting a Faster on my grapple bucket. The one thing you can't do anything about is when you tell them to install a #10 Seal Lok and the size is #8. Because you left the connection block at the shop.
/ Hydraulic Line Swivel? #16
“Wherever they fit good” has to be determined before the fittings are crimped. There is no changing things after the fact. Very doable when the tractor is near the hose fitting inventory and crimper. My comment about avoiding 2 angled fittings on a single hose speaks to this whole challenge. If you always have one straight fitting then a separate elbow fitting on one end this whole scenario is avoided.
/ Hydraulic Line Swivel? #17
We've "fine tuned" the position of two angled fittings even on 1 1/4" heavy equipment hoses. They do turn in the hose after krimping.
Just leave the hoses installed and turn them with a pipe wrench until the twist is gone and are in a position you like them. With this method, you can even "steer" a hose away from an area where it would rub.
/ Hydraulic Line Swivel? #18
Yes the couplers can swivel. If the 90's are as tight as you can get them, you may have to twist the hoses to connect the couplers. That is why I suggested a swivel connection on the hose connection. After everything lines up, torque them down.
All fixed and perfect. Local hydraulic shop cut the hoses at the coupler ends, installed 90* fittings on the couplers and put straight, full-time swivel connectors on the lines that now attach to the 90s. Now during operation the lines are able to swivel around the couplers and also swivel radially as the grapple moves. Thanks everyone, this is the way the grapple lines should have been installed in the first place.......
/ Hydraulic Line Swivel? #20
Those hoses will not turn in the fitting they are crimped and not very good at that as there should not be that big bulge where the fitting comes out of the crimp sleeve.
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61573)
2019 East...
HLA Attachments Loader Forks (A64119)
HLA Attachments...
(8) 18X8.50-8 GOLF CART TIRES & RIMS (A64281)
(8) 18X8.50-8 GOLF...
