Hydraulic lift hicups
/ Hydraulic lift hicups #1
WillieLandini
Oudtshoorn South Africa
International and Landini
I have an Mc cormick International 434. The hydraulic lift has hicups and lowers by itself when tractor is not running. Unless I close the valve on the front of the lift cover then the lift stay up. Anny idea where I can start looking for problem pleas?
/ Hydraulic lift hicups #3
/ Hydraulic lift hicups #4
see at top right ...thats where that piston with the small spring going in....you need to make a punch to remove that to replace all those o-rings ....some outside and one in one off those valvespacers
/ Hydraulic lift hicups #7
Now uyou can see all the valves in that hydraulics. The o- rings I am talking is on the inside of number 15
I have found some problems on the lowering spool and seat is worn so I wil get it fixed so it can seat corectly. And I will also replace all orings on lowering spool. Thanks for all the help and support DLTTrekkers
IMG_20180313_095307.jpg Looking for lowering spool and spool seat part number 3049 142 R93 if anny one can help pleas
Now I have the lowering spool and seat fixed I polished the seat and spool with bit of grinding with a soft grinding stone. I got everything back and in and put lift back but stil same problem. With all new orings and spool and seat fixed.
I have found the problem the copper washer behind the seat of the non return valve had a litle crack in it looks fine when looking at it but I took a torch and put a litle heat to it and there it was a small crack. Replaced the washer and now my lift is working fine.
MIDDLE BUSTER PLOW (A60430)
MIDDLE BUSTER PLOW...
JLG 2630ES ELECTRIC SCISSOR LIFT (A60429)
JLG 2630ES...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61306)
2020 Takeuchi...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
