Hydraulic level plug replacement
   / Hydraulic level plug replacement #1
Tullfish
Ford 4600
Hi,
I had a hard time removing a worn down level plug, and probably affected the female threads on the tractor case doing so. It seem to be a 1/2 inch tapered plug. If I find a replacement plug, could it kind of "re-thread" the female treads? Or should I re-thread the whole thing a size higher?
Sylvain
   / Hydraulic level plug replacement #2
There is a danger of getting metal filings in the hydraulic oil by re-threading. If you can find a replacement plug you should probably use some Teflon thread seal tape on it to get a good seal.
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
CATERPILLAR 299D2 SKID STEER (A51242)
CATERPILLAR 299D2...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2025 LandHonor PHA-16-2C Hydraulic 3 Point Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
