Hydraulic leak while running on JD 4020
   / Hydraulic leak while running on JD 4020 #1
Danny Barnett
Searcy, AR
4020 JD, 1530JD, 4230 JD, 4840 JD, 4430 JD, 4850 JD
I have a '65 4020 that leaks down on the 3 pt. hitch while using implements. Is this the rockshaft control valve and what will it take to stop the leaking down?
   / Hydraulic leak while running on JD 4020 #2
Leak down could be control valves leaking from not seating,piston seal or thermal relief valve leaking. Easiest thing to check is the piston seal by removing the cover in photo and replacing piston seal.
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
Case 570MXT Turbo Tractor Loader with Box Blade (A55787)
Case 570MXT Turbo...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
New Holland...
