Hydraulic leak while running on JD 4020
   / Hydraulic leak while running on JD 4020 #1
Danny Barnett
Searcy, AR
4020 JD, 1530JD, 4230 JD, 4840 JD, 4430 JD, 4850 JD
I have a '65 4020 that leaks down on the 3 pt. hitch while using implements. Is this the rockshaft control valve and what will it take to stop the leaking down?
   / Hydraulic leak while running on JD 4020 #2
Leak down could be control valves leaking from not seating,piston seal or thermal relief valve leaking. Easiest thing to check is the piston seal by removing the cover in photo and replacing piston seal.
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55218)
New Holland 1412...
2000 Ford F-250 4X4 Service Body Truck (A55788)
2000 Ford F-250...
Mobile toilet with shower (A55758)
Mobile toilet with...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
