Hydraulic issue on 1020 John deere
   / Hydraulic issue on 1020 John deere #1
Dizno
ON, Canada
John Deere 1020, John Deere 1030, John Deere AR, John Deere 455
The 47 loader model is connected to the rear SCVs. When the 3 point is up, it has no power. When the 3 point is down, then the loader has lots of power.
What is the issue?
   / Hydraulic issue on 1020 John deere #2
Can you give us more information ??
Has it ever worked correctly in this configuration ??
When did this start happening ??
Photo or two of how this is connected to rear SCV's may help
   / Hydraulic issue on 1020 John deere #3
Sounds as if 3 pt control valves aren't seating properly or valve seals have failed. Another problem could clearances between valve & operating linkage is incorrect. This clearance if a problem can be adjusted by turning an external screw. With hyd oil at operating temp, engine operating at idle speed, 3pt raised look into open hyd filler hole behind seat for moving/spraying oil. Moving oil indicates 3 pt valve seal failure which will require R&R of rockshaft housing/R&R of control valve seals to correct the problem.
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
yellow ball Trailer (A56859)
yellow ball...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
