Hydraulic hoses
   / Hydraulic hoses
Right now I am looking at Discount hydraulics to make up the hoses I need. 2 wire, 1/2 in, 3000 psi rated with jic female swivel on either end.
I have never worked with hydraulics a lot so this is a learning experience. I am adding a "D" spool motor controller and an "A" spool 3rd function to the front end while also a "T" in the 3rd function to the rear and panel mounting the rear connectors along with the power beyond connections to the backhoe.
Big learning curve, but i think I have it figured out.
   / Hydraulic hoses #12
We have a Carquest that will make Gates hoses.
   / Hydraulic hoses #13
Very fortunate here. We have a company in Spokane that deals with everything hydraulic. House of Hose. I've had them make up hose for me and purchased quite a bit hydraulic from them.
   / Hydraulic hoses #14
I'm kinda gun-shy on generic brands. I even have some made in usa Parker hoses that are cracking prematurely.
I had a local shop making my hoses for a while that used a different brand every time I went. One hose they sold me was made in Italy and failed in 3 years.
Hoping to have better luck with Gates.
   / Hydraulic hoses #15
Choose your hose carefully depending on how tight you will have to route them:​
R16-08 | 1/2" SAE 100R16 Hydraulic Hose has a bend radius of 3.5" &​
R2-08 | 1/2" SAE 100R2AT Hydraulic Hose has a bend radius of 7".​
I have used discount hydraulic hoses a few times in the past with very fast service. KC
   / Hydraulic hoses #16
A note on surplus center hoses. With these cheap hoses if the house could get bumped and is fairly small I wouldnt use a surplus center hose. I went through 2x on my excavator thumb then went to weather head brand. Granted this is a 1/4in hose.
I have surplus center 3/4in hoses on a log splitter and tractor loader with no issues.
For you needs..fairly well protected and fairly big, 1l/2in I would use surplus center hoses. I have also had prety good luck with chinese quick couplers. Although amazon was cheaper than surplus center.
Craftsman Utility Work Bench (A55272)
Craftsman Utility...
JOHN DEERE CS15 BATWING ROTARY MOWER (A58375)
JOHN DEERE CS15...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
UNUSED FUTURE STP45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
