Hydraulic hoses
/ Hydraulic hoses #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
I need information re hydraulic hoses, specifically from a FEL on a Bolens G214 ( Iseki- equivalent to a White Field Boss 21) This is a 1986 21hp 4wd with a FEL made in Fort Erie, Ontario by KMV Products with SAE bolts etc. Although the hoses don't leak the rubber was baked off by the sun and ,generally, looking pretty tough so I removed them. Unfortunately, the ends are different than the ones sold at Fleet-Farm that fit the Pioneer fittings. They are 3/8 hoses with 11/16 hex on the male side and 5/8 and 3/4 on the swivel- female side. The male side has an O-ring at the end of the threads about 3/8" from the end of the hose. Stamped on the metal male end is 10555-6-4 with a stylized"PH" in a rounded rectangle. Stamped on the metal female end is 1065564. Barely visible on the flaking rubber is "PARFLEX 560-4 WP 3000 PSI 1/4 ID QC61E1 (in the last 6 digits the Q may be an O & the 1 may be an I) I assume it's a Parker Hannifen 3000 lb working pressure 1/4" internal diameter. There are 4 pair,~ 16,20,28 and 36"long.
Is there an online source for such critters?
RCH
/ Hydraulic hoses #2
Sounds like the hoses on my FEL. I could check for sure if something doesn't turn up. The loader is a Pioneer, part of Farm King in Winnipeg. I believe Rath Farm Equipment, Arnprior, Ontario, installed the FEL and probably supplied the spooling valve as well. Both Farm King and Rath are on-line.
