Hydraulic hoses are difficult to re-connect
   / Hydraulic hoses are difficult to re-connect #11
   / Hydraulic hoses are difficult to re-connect #12
My goal is to leave this world just like I came into it. BROKE...
Wedge
   / Hydraulic hoses are difficult to re-connect #13
I've loosened the quick connector with a wrench to relieve the pressure, worked in my case as it was really locked up.
joel
   / Hydraulic hoses are difficult to re-connect #14
After disconnecting I just press the male tip and bleed a teaspoon or so amt of fluid into a catch container. This leaves enuf expansion room so pressure doesnt build up.
larry
   / Hydraulic hoses are difficult to re-connect #15
   / Hydraulic hoses are difficult to re-connect #16
Some where there was discussion on making a simple "U" shaped bracket with a nut welded to it and a bolt to press on ball (sort of like "C" clamp)... The DIY clamp has a spread base that goes around the coupler near lower end where threads are and the screw is long enough to thread down and put a bit of pressure on ball to relieve pressure...
OR you could do something like this... Actually modified QC...
Dale
   / Hydraulic hoses are difficult to re-connect #17
Those modified couplers would be nice to have. Does any body sell those?
   / Hydraulic hoses are difficult to re-connect #19
For some reason, I don't have this problem.
Before I disconnect the QC's I shut off the tractor and work all the hydraulic levers back and forth to relieve line pressure.
When I do disconnect, I only get a little weep of fluid and not under pressure.
   / Hydraulic hoses are difficult to re-connect #20
I do one extra step. After disconnect from the tractor supply, I reconnect the hoses to each other on the grapple side. and disconnect , and a bit more fluid will weep out. This leaves a "deficit" of fluid in the hoses. Then I connect the hoses to each other. Then even if temp changes or implement relaxes just a bit, since there is a deficit of fluid in the hoses, and pressure never builds. I NEVER have difficulty connecting hoses with this method. The other advantage is now the hoses are connected to each other and dirt/water cannot get in.
2023 GTC 39 END DUMP TRAILER (A50854)
2023 GTC 39 END...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A50854)
2013 INTERNATIONAL...
WEATHERGUARD TOOLBOX (A50854)
WEATHERGUARD...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
