Backhoe Hydraulic hose split on B2320
   / Hydraulic hose split on B2320 #1
ror105
Central PA
2011 Kubota 2320 HSD
Hi Fellas,
Haven't been on here in a while because the Kubota just keeps on running. Going on 9 years old with almost 500 hours and by far the best purchase I have ever made.
With all of that said, I was cutting the grass the other day, pulled up on the deck raise lever and got sprayed all over my back with hydraulic fluid (pretty sure this happened due to 'dead heading' the pump when the deck is at the top of it's travel and the engine is at high RPM. The leak is coming from the hose on the rear of the tractor that gets unplugged from the top rear of the tractor and plugged into the bottom of the BH65 backhoe. I tried to locate the proper term for this hose and can not distinguish it from 'power beyond' or 'rear remote' or maybe it is neither but I can't locate this particular hose on any parts website etc.
Can anyone tell me what the part number or name of this particular hose is so I can locate a new one? Also, I assume I am draining what hydraulic fluid is left in the system to replace this due to it going into the bottom of the tractor hydraulic system.
Appreciate any help I can get.
Thanks,
Rob
   / Hydraulic hose split on B2320 #2
Just take it off and bring the hose to a hydraulic shop or parts store and have a new one made its fast and easy......:)
Peter 315, back in the good old days that is what I would do. We are still on a bit of a lockdown here in Central PA and I'm a bit adverse to standing around in a store with a mask on. If it's something I can order online from Messicks, I would just as soon do that and have it on hand when I pull the old one. Not sure if I will save hydro fluid by doing it this way or not.
   / Hydraulic hose split on B2320 #4
Same here on lockdown I just had a hose made the other day when I got there I called them I had the hose in the back off my truck the guy come out and grabbed it it and made a new one I would just drain the oil out into a clean bucket. The hose might come with the backhoe kit if it is the power beyond hose.
   / Hydraulic hose split on B2320 #5
Did you try to look at the Messick's parts diagrams ?? They are very good. You could probably ID the hose from a diagram if it is an original part.
gg
Got the hose off, took it to NAPA, they had a new one made up in 20 minutes. $26, can't beat that. Thanks for the input fellows.
-Rob
   / Hydraulic hose split on B2320 #7
-Rob
Nice.........:thumbsup:
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2025 Swict 72in Bucket Skid Steer Attachment (A59228)
2025 Swict 72in...
2000 FORD F550 SUPER DUTY SERVICE TRUCK (A60430)
2000 FORD F550...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
UNUSED FUTURE 350 HYD BREAKER (A60432)
UNUSED FUTURE 350...
