Hydraulic hose question
/ Hydraulic hose question #1
frontyardfarm
ware, ma
Grillo 107D, Cub Cadet
Hi,
I have a 12 ton hydraulic press that I am trying to hook up to a hydraulic motor/pump. My question is: what psi hoses do i need? The pump will supply 24,000 psi to the hydraulic jack on the press. Does this mean I need a 24,000 psi hose? Almost all the hydraulic hoses I see are no more than 10,000 psi.
The company that sells the motor wants $250 for a 6ft length of 3/8 hose assembly. Sounds crazy expensive to me which is why i am looking around to see what i can find locally, but I am lacking the understanding of what psi hose i need.
Thanks in advance for any input you might have.
/ Hydraulic hose question #2
Man, that is a heck of a pump....you sure that PSI is right ?
I don't know much about hydraulic pumps, maybe it actually runs at a lower psi but still is able to build up the pressure in the jack part of the press. The pump does have a pressure switch that has settings up to 12 ton and the press has a gauge that goes up to 12.
/ Hydraulic hose question #6
If are going to use that much psi, you need a bigger press. A 4" cyl with 2000psi well put out 25133lbs.or just a hair over the max of a 12ton press.
/ Hydraulic hose question #7
frontyardfarm,
I stock 10,000 psi Gates industrial jack hose (on a reel) in 1/4 and 3/8 id.......with factory crimp fittings
You need to check the max pressure of the pump and max rating of the cylinder, you may not need 10k hose
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
26ft. Truck Box Body (A61573)
26ft. Truck Box...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
