hydraulic hose question
/ hydraulic hose question #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
anyone know the working pressure difference, if there is one, on a 1/2 steel braided cloth covered hose vs. and hose of the same type except it has a green stripe woven in? the kind that you can use the reusable fittings on. thanks , johnny
i'm with you there. couldn't find any code on it.
/ hydraulic hose question #4
To determine working pressure for your hose, we need to know either the manufacturer's part number or the SAE specification.
If your hose isn't marked, there's really no way to know what you have.
BTW, reusable hose fittings are available for a variety of hoses. You just need to make sure you have right ones for the hose you are using.
This is one case where you can NOT mix and match, even if the hoses appear to be the same size.
/ hydraulic hose question #6
Just what machine, did the hose come off? If you know the operating pressure of the machine it came from, then take it to the hyd shop and order a new one. Their new hose will probably exceed the pressure of the old one anyway. If it is long enough to cut and add a new fitting, maybe the hose guy will try and fix it for you. .
KMC 18' FIELD CULTIVATOR (A64278)
KMC 18' FIELD...
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2006 CHEVROLET TRAILBLAZER (A65054)
2006 CHEVROLET...
2018 Tycrop Vector Belt 22ft. VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
