hydraulic hose question
/ hydraulic hose question #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
anyone know the working pressure difference, if there is one, on a 1/2 steel braided cloth covered hose vs. and hose of the same type except it has a green stripe woven in? the kind that you can use the reusable fittings on. thanks , johnny
i'm with you there. couldn't find any code on it.
/ hydraulic hose question #4
To determine working pressure for your hose, we need to know either the manufacturer's part number or the SAE specification.
If your hose isn't marked, there's really no way to know what you have.
BTW, reusable hose fittings are available for a variety of hoses. You just need to make sure you have right ones for the hose you are using.
This is one case where you can NOT mix and match, even if the hoses appear to be the same size.
/ hydraulic hose question #6
Just what machine, did the hose come off? If you know the operating pressure of the machine it came from, then take it to the hyd shop and order a new one. Their new hose will probably exceed the pressure of the old one anyway. If it is long enough to cut and add a new fitting, maybe the hose guy will try and fix it for you. .
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
