hiddentacocatneddih
Platinum Member
- Joined
- Jan 31, 2019
- Messages
- 763
- Tractor
- Mahindra 485DI
I found steel hydraulic tubing for 4500psi in about 2 seconds on there by googling it
Yup. Here's the before (pardon my messy bench):You straightened a cylinder rod?!?
The shaft already had some dings and nicks in it, so I figured it wouldn't hurt to try. I used aluminum plates to protect the rod in the press. Any yeah, it took a while to get it as good as it got. Then I polished the rod in the lathe to try and smooth out the pre-existing dings, nicks, and rough spots. The rod was now straight enough I could run it in the lathe without too much vibration.Wow... nice! That must be a delicate operation, applying enough force in the right place to straighten the rod, without marring it to interfere with the cylinder rod seal.
Which crimper did you buy? The cheapest for proper JIC/an fittings was around $1500Bought my own hose and fittings and hand pump crimper cheaper than making four hoses yep it's insane
