Hydraulic hose covering
   / Hydraulic hose covering #1
DonRybak
Central FL
RK37HC
I've noticed recently that the fabric sleeve covering the hydraulic hoses from the control valve up between the loader and cabin is losing it's battle with the hot FL sun. It's just falling apart. My question is if there's any sense in replacing it? Seems that if replaced with another OEM one it'll just deteriorate too. Not sure what purpose the sheath serves other than maybe preventing wear on the hoses from the cabin. Can't be to protect the hoses from the sun since the last few feet of hoses are not covered. I had a thought that a better option than another OEM one would be to drop by the fire department and see if that have any old hoses they are throwing out and get a section on that to slide over. Any thoughts as to if I just use tie straps to keep them from rubbing and disregard the sleeve? Thanks.......
   / Hydraulic hose covering #2
I wonder the same thing. Mine is fraying on the bottom but I think that is from it rubbing against the tire when I make a sharp turn. Do the actual rubber hoses deteriorate quickly in the sun? Would the covering help shade the hoses?
   / Hydraulic hose covering #3
After loosing most all the hoses on my Kenbota to the South Texas sun, I covered them all when I replaced them. Central Florida can't be much different. The covering is cheaper than hoses. ;)
   / Hydraulic hose covering #4
What did you cover them with ?
   / Hydraulic hose covering #5
   / Hydraulic hose covering #7
If the sun has rotted out the sleeves/covers, that means (to me at least) that they have prevented the damage from getting to the actual hoses (not as extensive, of course).
I would replace them. Not a big deal if you don't, but might as well
   / Hydraulic hose covering #8
In addition to providing UV and abrasion damage, these sleeves protect you from pinhole hydraulic oil leaks which can be a serious injection hazard.
Thanks for the replies. The existing sleeve is largest enough that all four hoses pass through it. I didn't see any on those links that were that large in diameter but they could be done individually or two per sleeve. Seems odd that the existing sleeve only covers about 3/4 of the length of the 4 hoses and none of the shorter ones by the bucket are covered. Thanks again for the replies and links..............
   / Hydraulic hose covering #10
If U can get some fire hose like used in many commercial buildings it makes good protection sleeves.
Usually it is 1 1/4 inch hose and is mandated to be changed @ 5 years.
Great abrasion protection.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Utility Trailer (A52377)
Utility Trailer...
