r8f1k
- Joined
- Jul 21, 2018
- Messages
- 310
- Tractor
- Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
I have an old (1900-1910) hydraulic cider press. The ram comes up through the floor and presses upwards on a large frame. We pressed about 1000 lbs of apples on Saturday and I could not get the ram to hold under real pressure. It would easily push up with the pump running and then push back down once I shut the pump off. You could then hear a chatter like it was spinning the vane pump backwards and allowing fluid to head back to the tank. What do I do to get it to hold pressure? Do I need a check valve of some kind? Further enhancing the problem is that this is a single acting, gravity down, hydraulic cylinder that uses the same hose for pressure and return. Its about 10" in diameter and 38" long. I am running a Vickers vane pump and using typical hydraulic fluid. Any advice as how to get this animal working the way it should is welcomed. I should add that once upon a time, this press operated with gate valves where I think it was easier to open and close the path back to the tank. I am not using that anymore......thoughts?
