Hydraulic fluid
/ Hydraulic fluid #1
oafdawg
Sandusky Ohio
Mahindra Max 28
I'm having a tough time trying to find what type of hydraulic oil to run in my Max 28. The closest Mahindra dealer is over 60 miles away and I can't get a straight answer to which fluid would be compatible. Has anyone used Harvest King Premium Universal Tractor Trans-Hydraulic Fluid in their Mahindra without screwing things up?
/ Hydraulic fluid #2
In Ohio you must have a New Holland or CaseIH dealer in reasonable distance just get their Hytran fluid and you would be well covered.
Or go green and get Hygard fluid.
/ Hydraulic fluid #4
I've always used Shell in my Max 26xl. Typically from Tractor Supply because its close and always available. Screenshot_20200723-014812_Photos.jpeg
/ Hydraulic fluid #5
The local TS generally doesn’t have it in stock. Way less expensive then the Mahindra. It’s listed as equivalent to shell Donax and Spirax S4
/ Hydraulic fluid #7
Not sure if you have a NAPA auto parts store nearby, but I was able to get Chevron 1000 from them. I have a MAX 22 and it was listed as an OEM equivalent as already stated by doneill127. I had to special order it, but it arrived in a few days. Was a lot easier than driving to the dealer which is about 60 miles away for me also.
/ Hydraulic fluid #8
have them order it into the store and pick it up.
/ Hydraulic fluid #9
I had a neighbor/client that worked for Shell as a petroleum engineer.
Oil is oil.
Hydraulic is the cheapest cut.
Many products have simply specified non detergent oil for hydraulics.
The neighbor friend always ran his backhoe on SAE 30 non detergent, and that for some 20 years.
/ Hydraulic fluid #10
I'm not a Mahindra Owner... but if you have access to Schaeffer products as Birdhunter1 mentioned... I would high recommend them.... after using their product I wouldn't switch back....
2008 WABASH 53X102 T/A REFRIGERATED TRAILER (A59910)
2008 WABASH 53X102...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2016 Dodge 5500 Box Truck (A63116)
2016 Dodge 5500...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
