Hydraulic fluid
/ Hydraulic fluid #1
Usmcsrt1
Graniteville, SC
2016 Mahindra 2555 HST
Is hydraulic fluid something that slowly burns up and has to be topped off? And how often are you topping off your coolant reservoir? The reason I ask is I went around and checked all fluids and cleaned her up yesterday and the rear hydraulic dipstick was dry and the coolant overflow was below low line. I had to add approximately 1 quart of hydraulic fluid. I also had a new EA grapple and 3rd function kit added, so I'm thinking it filled those new hoses which caused it to be low. ButI would of thought the dealership would of accounted for that and added some. 2555HST with 50 hours.
/ Hydraulic fluid #2
No, hydraulic fluid, doesn't "burn off".
Yes, the dealer should have checked it, and added the appropriate amount.
Don't put all your faith in anyone else, including them. Things being overlooked are not rare occurrences.
I don't know how much hydraulic fluid your tractor holds. But it's many gallons. So, being a quart low, is non issue.
/ Hydraulic fluid #3
I think your tractor holds close to 10 gallons of hyd fluid. Depending on how you use your tractor, you can loose a little radiator fluid just sloshing around in the overflow tank. If you fill it to the line, it will go up when the liquid is hot. And likewise go down with cold. Just like air pressure in a tire. Like ray66v stated, life is better if you be pro-active and take care of stuff yourself. Not that the dealer should have top'd it off, but you should climb and crawl all around your tractor checking for leaks, tighten bolts, etc. Good way to get to know your tractor, wiggle stuff, and spend some quality time with it..... :)
/ Hydraulic fluid #5
you would be surprised how much you loose in those hoses. and also disconnecting and reconnecting
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Caterpillar 16G Motor Grader Parts and Service Manuals (A63117)
Caterpillar 16G...
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
2009 Honda Pilot AWD SUV (A61574)
2009 Honda Pilot...
