Oil & Fuel Hydraulic Fluid
/ Hydraulic Fluid #1
FloridaCracker
Space Coast, Florida
2000 Kubota L2600DT
Hey guys,
I purchased my tractor about two months ago. Since then I've put about five hours on the FEL. The guy I purchased it from owns an auto mechanic shop and so he put all new hydraulics on the tractor since the lines were original and cracking, etc. He did not replace the oil or fuel filter - he just wanted the tractor in sellable condition. He did give it an oil change (weird to do an oil change but not replace the filter?). I got to thinking after reading a couple posts about hydraulic fluid; I don't know what kind of fluid he put in the tractor. I guess I could call but I'd be annoyed if folks are calling me two months after I sold something. I presume the fluid is cheapo stuff. My question is if you were in my shoes would you replace the hydraulic fluid with what you know - the good stuff? Or would you not worry about it, considering it hasn't given me any problems.
Thanks,
Brian
2000 Kubota L2600DT
/ Hydraulic Fluid #2
I would just change ALL the fluids. If nothing else at least you would have piece of mind. And then you would know how to change and how much everything takes.
/ Hydraulic Fluid #3
I would be inclined to replace all fluids and filters and then go by the manual recommendations on service from there. Be sure to keep records as you might forget what and when you replaced it. I use to put the date on my filters.
It is not unusual to change oil without changing the filter or filter without changing the oil.
Good luck with your new tractor.
/ Hydraulic Fluid #4
As the other guys have already mentioned, change all fluids and filters for your peace of mind. IMHO, you wouldn't have posted your question if you didn't already have doubts.
/ Hydraulic Fluid #5
i'd do a full service.
I wouldn't be worried so much that he used cheap oil.. that's what I use in my small fleet of tractors :) I'd be more concerned that he used the correct spec oils..
thus a full service is a good baseline for you to put in your maintenance records.
soundguy
/ Hydraulic Fluid #6
I agree, I would do a full service if it were mine.
Then I know for sure what was done.
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
JOHN DEERE S690 COMBINE (A64278)
JOHN DEERE S690...
2011 Ford F-550 4x4 Altec AT37G 37ft. Bucket Truck (A64556)
2011 Ford F-550...
