hydraulic fluid leaking from top of steering column john deere 2020
   / hydraulic fluid leaking from top of steering column john deere 2020 #1
howardweed
schuylerville ny
john deere 2020
I have an early john Deere 2020 that had a power steering pump and an open center steering column.
The pump failed so I put a closed center column on it and hooked it up to the main hydraulic pump
The steering works fine but there is a small stream of oil coming out of the top of the steering column.
can this be fixed without removing the steering column?
   / hydraulic fluid leaking from top of steering column john deere 2020 #2
You could try replacing top seal under steering wheel but IIRC to solve oil leak I think you're going to have to replace a deeper o-ring.
   / hydraulic fluid leaking from top of steering column john deere 2020 #3
All 6 of them in the correct grooves !
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2019 FORD F-150 (A50854)
2019 FORD F-150...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
