hydraulic fluid leaking from top of steering column john deere 2020
   / hydraulic fluid leaking from top of steering column john deere 2020 #1
howardweed
schuylerville ny
john deere 2020
I have an early john Deere 2020 that had a power steering pump and an open center steering column.
The pump failed so I put a closed center column on it and hooked it up to the main hydraulic pump
The steering works fine but there is a small stream of oil coming out of the top of the steering column.
can this be fixed without removing the steering column?
   / hydraulic fluid leaking from top of steering column john deere 2020 #2
You could try replacing top seal under steering wheel but IIRC to solve oil leak I think you're going to have to replace a deeper o-ring.
   / hydraulic fluid leaking from top of steering column john deere 2020 #3
All 6 of them in the correct grooves !
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
