hydraulic fluid leaking from top of steering column john deere 2020
   / hydraulic fluid leaking from top of steering column john deere 2020 #1
howardweed
schuylerville ny
john deere 2020
I have an early john Deere 2020 that had a power steering pump and an open center steering column.
The pump failed so I put a closed center column on it and hooked it up to the main hydraulic pump
The steering works fine but there is a small stream of oil coming out of the top of the steering column.
can this be fixed without removing the steering column?
   / hydraulic fluid leaking from top of steering column john deere 2020 #2
You could try replacing top seal under steering wheel but IIRC to solve oil leak I think you're going to have to replace a deeper o-ring.
   / hydraulic fluid leaking from top of steering column john deere 2020 #3
All 6 of them in the correct grooves !
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2018 Nissan Murano S SUV (A50324)
2018 Nissan Murano...
71060 (A49346)
71060 (A49346)
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
