Hydraulic Fluid for 1997 M5400S
/ Hydraulic Fluid for 1997 M5400S #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
Wanted to determine what kind of hydraulic fluid you are using in your tractor? I used the Kub UDT before, but the price has skyrocketed. I know it's much cheaper to use expensive hyd-fluid vs a trip to the dealer to fix my hydraulic system. However, has anyone found a suitable alternative that performs well?
Usage: total of 910 hrs since Jan 1997, so light usage for weekend farmer at best
Environment: Subjected to much more heat than cold...SE texas region, tractor always kept inside shed when not in use. Shed is cedar pickets w corrugated metal roof, meaning, not climate controlled.
Thanks,
tstex
Synchronized shuttle
The 1997-era Kubota M-Series tractors (such as the M5400) primarily utilize a
synchromesh transmission with a mechanical shuttle shift, allowing for easier direction changes. These models typically feature 8 forward and 8 reverse gears (8F/8R) or a 12F/12R configuration, designed for high-performance utility work.
Key Transmission Details:
  • Shuttle Shift: Features a column-mounted lever for forward/reverse, facilitating quick directional changes.
  • Gear Drive: A manual transmission, usually requiring the clutch for range changes.
  • Speed Configurations: Commonly 8 or 12 forward speeds, depending on the specific model variation within the M-Series range.
  • Utility Focus: Built for heavy-duty, all-day operation.
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
(10) 36' HEAVY DUTY INSULATED PANELS (A62131)
(10) 36' HEAVY...
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
