Hydraulic fluid coming out of trans at shifter
   / Hydraulic fluid coming out of trans at shifter #1
grsr3
Put new pump on my Kama TS254 and filled reservoir-----which is stacked higher than tranny. Hydra fluid now coming up from bottom of shift lever. I thought the two different reservoirs were internally separated. Could something inside have busted when the pump cracked???
   / Hydraulic fluid coming out of trans at shifter #2
Can you post a picture of your tank?
On a Jinma 254 (which I think is the same thing) the hydro tank is under the seat above the rear diff/transmission. There is nothing in common between the two so there should never be any mixing. IF the bottom of the Hydro tank broke it could leak into the differential but that would be about the only thing I could think of.
I am guessing your pump is engine mounted and no where near either the transmission or the hydro tank.
What year is your tractor?
   / Hydraulic fluid coming out of trans at shifter #3
They are separate. That really should not be happening. Is it coming out as you raise and lower the lift? You replaced the pump on the pto, the one on the back of tractor?
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
