Hydraulic fluid coming out of trans at shifter
   / Hydraulic fluid coming out of trans at shifter #1
grsr3
Bronze Member
Put new pump on my Kama TS254 and filled reservoir-----which is stacked higher than tranny. Hydra fluid now coming up from bottom of shift lever. I thought the two different reservoirs were internally separated. Could something inside have busted when the pump cracked???
   / Hydraulic fluid coming out of trans at shifter #2
Can you post a picture of your tank?
On a Jinma 254 (which I think is the same thing) the hydro tank is under the seat above the rear diff/transmission. There is nothing in common between the two so there should never be any mixing. IF the bottom of the Hydro tank broke it could leak into the differential but that would be about the only thing I could think of.
I am guessing your pump is engine mounted and no where near either the transmission or the hydro tank.
What year is your tractor?
   / Hydraulic fluid coming out of trans at shifter #3
They are separate. That really should not be happening. Is it coming out as you raise and lower the lift? You replaced the pump on the pto, the one on the back of tractor?
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
2023 BOBCAT T770 SKID STEER (A51246)
2023 BOBCAT T770...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
