Hydraulic flow restrictors
/ Hydraulic flow restrictors #51
If you put it on the input side of the valve, wouldn't that affect all four motions of the joystick?
<font color="blue">"... wouldn't that affect all four motions of the joystick?" </font>
Yeah, that's what it should do, which would be better than stock but not as good as having individual restrictors. Easier and cheaper to do tho. Too late for me. I'm pretty happy with the way my controls work now.
By the by, Scott sent me the treadle springs. I like having them installed MUCH better than before.
I assume (yeah, yeah, I know!) that everyone here already knows that Scott is expecting a new daughter in April.
Phil
/ Hydraulic flow restrictors #53
Nope. Didn't know that. Please wish him the best from all of us here at TBN if you talk to him. /forums/images/graemlins/grin.gif
/ Hydraulic flow restrictors #54
Sure would, but if you trying to slow every thing down, that's the way to go. Just some different options. That's all.
/ Hydraulic flow restrictors #55
You know what... that got me thinking... uh-oh. /forums/images/graemlins/tongue.gif
My daughter is always wanting to drive the tractor. I had her out snow plowing a couple weeks ago, and the main thing she had trouble with was the speed of the hydraulics on the FEL. If I put in a flow restrictor before the valve, I could adjust it for her.
However, isn't the valve an open center type, so that all the flow just sails directly through the valve until you direct some at one of the cylinders by moving the joystick or aux PTO knee lever? If you restricted it before the valve, wouldn't that cause some problems by changing the pressure in the line possibly overloading the pump? That's my understanding of open center. It has to remain open with no obstructions. Anybody else agree or disagree?
/ Hydraulic flow restrictors #56
I think what you need, is called Adjustable Priority Flow Divider valve. I would call Bailey 1-800-8001810. and tell them what you are trying to do. Good Luck
/ Hydraulic flow restrictors #57
The adjustable flow controls may be the least expensive way to go. If you decide on that route, I would check Ebay, I see them listed all the time. I think Phils got his very reasonable.
I believe you are right about the pump, if you stop the fluid, the relief valves will start to chatter.
INOP/NON-RUNNING 2012 Jaguar XJ Passenger Car, VIN # SAJWA2GE5CMV37496 (A61165)
INOP/NON-RUNNING...
SD Lanch SDLGC80 Electric Golf Cart (A60463)
SD Lanch SDLGC80...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
1997 Wilson Pacesetter 8'x42' Hopper Bottom (A60462)
1997 Wilson...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
