hydraulic flow on a JD 544G - 1993
   / hydraulic flow on a JD 544G - 1993 #1
kingriver
Hey ,, I am trying to get information on the amount of hydraulic flow this unit has. I am hoping that is doesn't exceed 40. Any help pointing me in the right direction to find out would be great.
Thanks
:confused:
   / hydraulic flow on a JD 544G - 1993 #3
46.3 GPM
HYDRAULIC SYSTEM/STEERING
Pump (loader and steering).............................gear-type, open-center system gear-type, open-center system gear-type, open-center system
Maximum flow.........................................46.3 gpm (175 L/min.) @ 600 psi (4137 kPa) 61 gpm (231 L/min.) @ 600 psi (4137 kPa) 69.5 gpm (263 L/min.) @ 600 psi (4137 kPa)
and 2,200 rpm and 2,200 rpm and 2,200 rpm
Pressure.....................................................loader relief 2,750 psi (18 961 kPa) loader relief 2,800 psi (19 306 kPa) loader relief 3,000 psi (20 685 kPa)
steering relief 2,650 psi (18 270 kPa) steering relief 2,650 psi (18 270 kPa) steering relief 2,650 psi (18 270 kPa)
Loader controls ...............................................two-function valve with single lever and two-function valve with single lever and two-function valve with single lever and
control lever lockout control lever lockout control lever lockout
Hydraulic cycle times
Raise..........................................................5.8 sec. 5.8 sec. 6.2 sec.
Dump........................................................1.4 sec. 1.7 sec. 1.8 sec.
Lower ........................................................3.2 sec. (float down) / 3.5 sec. (power down)
   / hydraulic flow on a JD 544G - 1993 #4
Beat you to it JJ..:laughing:
"Great minds run in the same paths"...........:thumbsup:
   / hydraulic flow on a JD 544G - 1993 #5
That is because you are younger.
   / hydraulic flow on a JD 544G - 1993 #6
I don't know about that.....after trying to follow my furbuddy houndleys through the woods today, my bones don't agree with you......and tomorrows run is on the agenda also.......:confused2:
Old is a subjective analogy.........
Two Post Car Lift (A50120)
Two Post Car Lift...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
