hydraulic flow on a JD 544G - 1993
   / hydraulic flow on a JD 544G - 1993 #1
kingriver
Hey ,, I am trying to get information on the amount of hydraulic flow this unit has. I am hoping that is doesn't exceed 40. Any help pointing me in the right direction to find out would be great.
Thanks
:confused:
   / hydraulic flow on a JD 544G - 1993 #3
46.3 GPM
HYDRAULIC SYSTEM/STEERING
Pump (loader and steering).............................gear-type, open-center system gear-type, open-center system gear-type, open-center system
Maximum flow.........................................46.3 gpm (175 L/min.) @ 600 psi (4137 kPa) 61 gpm (231 L/min.) @ 600 psi (4137 kPa) 69.5 gpm (263 L/min.) @ 600 psi (4137 kPa)
and 2,200 rpm and 2,200 rpm and 2,200 rpm
Pressure.....................................................loader relief 2,750 psi (18 961 kPa) loader relief 2,800 psi (19 306 kPa) loader relief 3,000 psi (20 685 kPa)
steering relief 2,650 psi (18 270 kPa) steering relief 2,650 psi (18 270 kPa) steering relief 2,650 psi (18 270 kPa)
Loader controls ...............................................two-function valve with single lever and two-function valve with single lever and two-function valve with single lever and
control lever lockout control lever lockout control lever lockout
Hydraulic cycle times
Raise..........................................................5.8 sec. 5.8 sec. 6.2 sec.
Dump........................................................1.4 sec. 1.7 sec. 1.8 sec.
Lower ........................................................3.2 sec. (float down) / 3.5 sec. (power down)
   / hydraulic flow on a JD 544G - 1993 #4
Beat you to it JJ..:laughing:
"Great minds run in the same paths"...........:thumbsup:
   / hydraulic flow on a JD 544G - 1993 #5
That is because you are younger.
   / hydraulic flow on a JD 544G - 1993 #6
I don't know about that.....after trying to follow my furbuddy houndleys through the woods today, my bones don't agree with you......and tomorrows run is on the agenda also.......:confused2:
Old is a subjective analogy.........
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
