HYDRAULIC FLOW CONTROL
/ HYDRAULIC FLOW CONTROL #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I've seen several posts regarding speed of operation of top links and grapple jaws, that you may want to improve control by using 1/4" hoses, rather than larger. Can you buy a "rheostat" like in-line control that can be adjusted within a range to suit the usage, but keep larger hoses for higher flow applications. Frankly, I'm asking this question because I saw a flow control device in a catalog and it seemed like it might be useful.
/ HYDRAULIC FLOW CONTROL #2
There are flow diverters and flow restrictors. Flow restrictors usually have free flow in one direction and restricted flow in the other. Some are adjustable and some are fixed.
Surplus Center
It looks like one of the valves in your link is fully adjustable and/or gives one way flow control.
/ HYDRAULIC FLOW CONTROL #4
The problem with the devices that restrict flow in only one direction is that you wil probably need 2 of them, one on each work port hose, to control the speed in both directions. I find it easier to use smaller diameter hoses. Usually the hoses stay with the implement cylinder so I don't really see a need for your concern regarding keeping larger hoses.
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
Hickory Lumber (A65640)
Hickory Lumber...
John Deere 4044R (A62177)
John Deere 4044R...
Wooden Totem Pole (A64127)
Wooden Totem Pole...
