hydraulic flow control
/ hydraulic flow control #1
jerrym4
Wyoming
I just purchased a Daewoo skid steer with a 4-n-1 bucket. It works great except I'd like to restrict the hydraulic flow a bit. Does anyone know of an after market valve that is easy to install and remove when not needed?
Thanks,
Jerry
Thanks,
Jerry
/ hydraulic flow control #3
Check into SurplusCenter.com
I've purchased a number of flow control valves from them. Line size is one spec you will need, and reverse free flow is usually desireable. I put one on each line to restrict flow going to the ram.
Or you can get flow restricters, that are flat washers with pin-hole size orifice in them, and you will need to play with the numbers or experiment to get the right flow restriction.
Surplus Center flow control
/ hydraulic flow control #4
I took your advice. Installed them a couple of days ago and they work very well.
Thanks,
Jerry
Thanks,
Jerry
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
Timpte Hopper Bottom (A63688)
Timpte Hopper...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
