hydraulic flow control
/ hydraulic flow control #1
jerrym4
Wyoming
I just purchased a Daewoo skid steer with a 4-n-1 bucket. It works great except I'd like to restrict the hydraulic flow a bit. Does anyone know of an after market valve that is easy to install and remove when not needed?
Thanks,
Jerry
Thanks,
Jerry
/ hydraulic flow control #3
Check into SurplusCenter.com
I've purchased a number of flow control valves from them. Line size is one spec you will need, and reverse free flow is usually desireable. I put one on each line to restrict flow going to the ram.
Or you can get flow restricters, that are flat washers with pin-hole size orifice in them, and you will need to play with the numbers or experiment to get the right flow restriction.
Surplus Center flow control
/ hydraulic flow control #4
I took your advice. Installed them a couple of days ago and they work very well.
Thanks,
Jerry
Thanks,
Jerry
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Dodge 5500 Bucket Truck (A63688)
Dodge 5500 Bucket...
