hydraulic flow control
   / hydraulic flow control #1
jerrym4
Wyoming
I just purchased a Daewoo skid steer with a 4-n-1 bucket. It works great except I'd like to restrict the hydraulic flow a bit. Does anyone know of an after market valve that is easy to install and remove when not needed?
Thanks,
Jerry
Thanks,
Jerry
   / hydraulic flow control #3
Check into SurplusCenter.com
I've purchased a number of flow control valves from them. Line size is one spec you will need, and reverse free flow is usually desireable. I put one on each line to restrict flow going to the ram.
Or you can get flow restricters, that are flat washers with pin-hole size orifice in them, and you will need to play with the numbers or experiment to get the right flow restriction.
Surplus Center flow control
   / hydraulic flow control #4
I took your advice. Installed them a couple of days ago and they work very well.
Thanks,
Jerry
Thanks,
Jerry
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2005 International 8600 Hydro Vac Truck (A53117)
2005 International...
