Hydraulic float
/ Hydraulic float #1
Ffluent
New Jersey
b7100hst
I have a B7100hst with a 2020 kubota blade Until recently, the float position worked, about a month ago, the float would not work until it warmed up. a week ago, same thing, but longer time to warm. Now it will not go into float at all. Initially the hydraulics operate very slowly, the blade will turn, but will not raise. Then the blade will raise a little more and more, and when I set the lever in float, it will raise the front off the ground.
/ Hydraulic float #2
Let's start with something simple. When is the last time you changed your trans/hydraulic fluid and filter?
/ Hydraulic float #3
If your control valve is similar to the Nimco on the Massey Ferguson GC series, you might want to read this thread
[URL="http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/53164-gc2300-got-float.html"[/URL]
/ Hydraulic float #4
I would suspect you have water collected in the end of the valve and it's freezing. Is the tractor stored outdoors where it gets rained on? How old is the hydraulic fluid?
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2018 Trail King Lowboy (A63118)
2018 Trail King...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2018 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
