Hydraulic fittings and hoses
   / Hydraulic fittings and hoses #1
kbone1
St.Augustine, Florida
JM 354
Hey guys,
I got a question; I am in the process of converting my ZL-30 FEL on my JM 354 to a Prince loader valve. I am buying Metric female to NPT male converter couplings, should I use ½ or 3/8 inch hose? Also if anyone has done this, has the same type/style of tractor and has some pointers, please let me know.
I would also like to hear from anyone who has replaced their Quick Connects. What type, style, size did you replace them with?
Was it hard to do?
Thank you,
kbone1
   / Hydraulic fittings and hoses #2
Kbone, we have a conversion kit already with a Koyker type valve with float, joystick,6- new hoses with JIC fittings,,new mounting bracket,adaptor fittings,just bolt up and your ready to go,you can install the complete new valve kit in about a hour.Did you already buy the Prince valve?? This is a better valve and set up.We use 1/2" hoses
Tommy
Affordable Tractor Sales Co.,
AFFORDABLE TRACTORS
   / Hydraulic fittings and hoses #3
Based on your hydraulic flow, 3/8" hoses should be adequate. Anything bigger is probably overkill. Make sure you use 2-wire hoses.
Adapter fittings can be had from Discount Hydraulic Hose.
If you don't already have a valve, then Tommy's kit is a good deal.
1995 Rinker Captiva 190 (A53473)
1995 Rinker...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2016 INTERNATIONAL MA025 BOX TRUCK (A53426)
2016 INTERNATIONAL...
