Hydraulic Filters on 1967 Ford 3000 Tractor
   / Hydraulic Filters on 1967 Ford 3000 Tractor #1
browndd1
Does anyone know how to change the hydraulic filters on a 1967 Ford 3000 Tractor (Gas)?
Thanks
   / Hydraulic Filters on 1967 Ford 3000 Tractor #2
Remove the hitch cover to access the return filter. Then remove the PTO shaft and probably the LH access cover to get to the suction screen.
   / Hydraulic Filters on 1967 Ford 3000 Tractor #3
What about on a 1975 Ford 2000 diesel?I am looking to change out the oil there and would like to clean the screens too!
Thanks
What are you referring to the hitch cover?
   / Hydraulic Filters on 1967 Ford 3000 Tractor #6
The large cast housing bolted on top of the rear axle center section. It contains the 3 point hitch rockshaft. If you have to ask what it is, buy a service manual before attempting to remove it.
Where is the left hand acces cover located?
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
1264 (A50490)
1264 (A50490)
