Hydraulic Filters on 1967 Ford 3000 Tractor
   / Hydraulic Filters on 1967 Ford 3000 Tractor #1
browndd1
Member
Does anyone know how to change the hydraulic filters on a 1967 Ford 3000 Tractor (Gas)?
Thanks
   / Hydraulic Filters on 1967 Ford 3000 Tractor #2
Remove the hitch cover to access the return filter. Then remove the PTO shaft and probably the LH access cover to get to the suction screen.
   / Hydraulic Filters on 1967 Ford 3000 Tractor #3
What about on a 1975 Ford 2000 diesel?I am looking to change out the oil there and would like to clean the screens too!
Thanks
What are you referring to the hitch cover?
   / Hydraulic Filters on 1967 Ford 3000 Tractor #6
The large cast housing bolted on top of the rear axle center section. It contains the 3 point hitch rockshaft. If you have to ask what it is, buy a service manual before attempting to remove it.
Where is the left hand acces cover located?
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Landoll Hauloll (A52128)
Landoll Hauloll...
Payment Terms (MUST READ) (A50774)
Payment Terms...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
