Hydraulic Filters on 1967 Ford 3000 Tractor
   / Hydraulic Filters on 1967 Ford 3000 Tractor #1
browndd1
Does anyone know how to change the hydraulic filters on a 1967 Ford 3000 Tractor (Gas)?
   / Hydraulic Filters on 1967 Ford 3000 Tractor #2
Remove the hitch cover to access the return filter. Then remove the PTO shaft and probably the LH access cover to get to the suction screen.
   / Hydraulic Filters on 1967 Ford 3000 Tractor #3
What about on a 1975 Ford 2000 diesel?I am looking to change out the oil there and would like to clean the screens too!
What are you referring to the hitch cover?
   / Hydraulic Filters on 1967 Ford 3000 Tractor #6
The large cast housing bolted on top of the rear axle center section. It contains the 3 point hitch rockshaft. If you have to ask what it is, buy a service manual before attempting to remove it.
Where is the left hand acces cover located?
2016 ROADTEC RP-190E ASPHALT PAVER (A51222)
2016 ROADTEC...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2016 GMC Terrain SLE-1 (A50324)
2016 GMC Terrain...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
