Hydraulic filter?
/ Hydraulic filter? #1
nealfris
Marshfield, MA / Arlington, VT
Kubota '2003' L3000DT 8/4 std, engine/pto hp 32.1/27.5, hyd 6.9 gal/min
Why doesn't my '2003' L3000DT have a hydraulic fluid filter? Manual says there is a strainer mentioned in the maintenance schedule. Should I install a filter? I have a loader and BH on remotes and intend on adding more remotes. I've seen video on 3rd function installs that shows a filter and block under right step. Is this factory on newer models or after market? If I copy that design could I add several remotes at that location with a multiple bock?
/ Hydraulic filter? #3
I have an FEL on my L3000 dt, I just put a spin-on oil filter on the return line for the loader. the filter is behind the seat now, returns to the tank via 2 foot hose.. The strainer is at the bottom of the case, and i haven't had it out yet, as the oil is clean and clear. I believe the filter will help keep all the cylinders and valves in better shape now.Jy.
King Kutter 5' 3-Pt Gear Driven Rotary Tiller (A66285)
King Kutter 5'...
PEQUEA TT4100 TURBO TEDDAR (A64277)
PEQUEA TT4100...
2011 FREIGHTLINER FLD120 FLATBED (A65643)
2011 FREIGHTLINER...
2010 FREIGHTLINER FLD120 SD (A65643)
2010 FREIGHTLINER...
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
JOHN DEERE 5403 TRACTOR (A65643)
JOHN DEERE 5403...
