Hydraulic filter for a Hinomoto E324
   / Hydraulic filter for a Hinomoto E324 #1
iloveketchup
Hinomoto E324
The only part number on it i can find is 554240. Anyone know what this tractor uses or a cross reference?
   / Hydraulic filter for a Hinomoto E324 #2
This is probably going to get you in the correct range. It's not rocket science, you just want to get a flter that is not too restrictive but gives good filtration and is the correct size. You have a 3S150 92ci Hino engine The MF1035 has a MS150 92ci Hino engine and I'm sure similar (maybe the same) hydro pump/capacities/filtration requirements, etc.....in other words, sometimes you just don't have anything else to go by other than educated guess/speculation, which is what we've discussed to be a common problem with these tractors from day one. Now someone more familiar with your tractor may jump in and be able to tell you the exact filter # for every filter manufacturer that is a match for the 324 but this is what I got off the WIX site by looking at what works for Masseys/what might be closest to the 324. You can cross reference the WIX numbers to other brands online if you want to use something else, I just like WIX filters.
WIX Filters : Filter Look-Up
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2000 TEREX T560 CRANE TRUCK (A59905)
2000 TEREX T560...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
207277 (A52708)
207277 (A52708)
BLUE DIAMOND HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND HYD...
