Hydraulic filter change
/ Hydraulic filter change #1
NWOH_Grizz
NW Ohio
NH T2310
First time to change the HST and main hydraulic filters on my T2310 (TC40). Dealer says buy large jug of hydraulic fluid as I'm going to loose a bunch of it when I change the main filter.
It is located inside the frame behind the RR wheel, accessible from underneath. How much should I expect to lose when changing that big filter?
Just getting over sticker shock for 2 filters (hydraulic and HST) and 2 quarts of fluid -$85. I'm not going to complain any more about spending $15 for a chrome oil filter for the Harley.
/ Hydraulic filter change #2
Seems to me the filters will hold close to the 2 qts. With my experience you will continue to leak oil as you change the big filter so better be prepared to change it fast. Two quarts may not be enough.
/ Hydraulic filter change #3
I just changed out thehydraulic filter in my TD95D and The spill didn't come from the filter itself which I would estimate holds about one quart of fluid. It came from the filter head and was continuous until I put the filter on and tightened it. I had to add about two quarts of fluid to bring the the reservoir level up to the proper level.
/ Hydraulic filter change #4
The solution to filter changing messiness is to drain the fluid into clean containers or containers lined with double garbage bags. When filter changing is done, decant the fluid into a dollar store pitcher and use a long neck funnel to put it back into the reservoir. It will take two 5-gallon containers to hold all the fluid, so have two prepared and ready to do the changeout mid-stream while draining. An flat oil drip pan under the buckets will ensure your garage floor is not stained nor any oil spilled on your grass.
If you try to put a catch pan under the filter while removing it, you will wash the outside of the filter and and other parts with the fluid and contaminate it as it drains into the catch pan. By draining from the drain plugs and catching the oil ahead of time, you will only lose the quart inside the old filter. I suggest prefilling the new filters to 90% before installation so you don't put so much air into the system when you start the engine after the change.
BTW: When you pre-drain the fluid, you will probably notice that you only get 8 gallons out of the reservoir. The remaining two gallons are in the 3PH cylinder, the pump, the loader (if you have one), the HST transmission and cooler, and the catch nooks and crannies in the transmission case. You never get it all. To get the most possible, remove the plug on the front-wheel drive dropbox at the front of the transmission in addition to the two drain plugs on the reservoir.
/ Hydraulic filter change #5
It makes no sense to me to drain all the fluid from a NH Class II or III compact in order to accomplish a simple filter change.
Changing the hydro filter will spill about a cup of fluid. Changing the main suction filter will spill about 2 quarts if your reservoir is not overfilled to begin with. Taking an awl and poking a hole in the bottom of the main filter as a drain, followed immediately by another hole near the top of the filter to let air enter will yield less than two quarts of contaminated oil mainly from the dirty side of the filter media. There is no good reason to pour this small quantity of dirty oil back into the tractor.
/ Hydraulic filter change #6
Park your TD on a slight uphill grade next time you change the hydraulic filter.
/ Hydraulic filter change #7
Thanks for the tip Rick. I figured filter head was below the reservoir level and Ii was draining fluid through the suction line to the pump with the filter off.
/ Hydraulic filter change #8
Good point Rick. Still, the 50-hour service and filter change is to ensure manufacturing debris that might be in the filter are removed. By draining the reservoir, you will open the very bottom of the reservoir pool and heavier particles that might not get picked up by the normal suction and strainer would be washed out to some extent. That's why some drain plugs have a magnet installed. Inspecting your fluid and for condition and water plus looking for metal in the bottom of the reservoir are two valid reasons to drain the oil at 50 hours.
On my tractor, I returned it to the dealer and he did the 50-hour. It also gave him a chance to repair acid damage around my radiator behind the battery.
/ Hydraulic filter change #9
The OP doesn't say anything about a complete hydraulic oil change, and if that was his intention, his dealer would surely recommend more than one "large jug of hydraulic fluid" to accomplish it.
I'm just assisting with what the OP is trying to complete; changing his hydraulic and hydro filters.
/ Hydraulic filter change #10
I also am not suggesting changing the fluid. I'm suggesting draining into a clean container, inspecting, and returning it to service. I never suggested changing in any post in this thread unless the oil looks to have contamination. If you feel confident that the oil is okay, I certainly don't think it would wrong to not inspect it and simply change the filters and return to service after a simple topping off.
/ Hydraulic filter change #11
I'm going to continue to disagree with that strategy.
Not many owners are going to that effort, or will tolerate paying someone else to do it. Dirty oil will show up in the filter; that's what a filter does, trap contaminants. Beyond that, draining oil and pouring it back after a look-see is a great way to introduce more garbage into the oil than it already has in it to begin with.
/ Hydraulic filter change #12
Somehow, I just knew you were going to say that.:D:D:D I suppose the fact that I thought you'd say that means I'm also concerned with additional contamination. I think the OP's dealer scared him when he suggested he buy a big jug of oil. He needs 1-gal at most and will probably have almost half left over for topoffs (front axle and power steering also) during the next 250 hours to the 300 hour change. I think you would agree that prefilling filters is a good practice. Besides, changing filters is supposed to get your hands and clothes a bit dirty. It's a guy thing.;)
NWOH_Grizz needs to be aware that the HST filter will be VERY tight. I don't know anyone here on TBN who has not noticed that the factory has a "500 lb gorilla" tightening these filters. He will need a good filter wrench to get that filter off and he needs to tighten back down to nearly as tight as the original due to the high pressures often seen in this system. I use oil filter pliers like these to remove filters.
/ Hydraulic filter change #13
I like the idea of draining the complete system after 50 hour to ensure that all the crap from manufacturing is out of the system. This gives you an opportunity to inspect the oil and view any contaminate that may be in the oil and allows you to have the option of changing all the oil or filtering out any small particals left in the oil.
/ Hydraulic filter change #14
I do not pre-fill any filters unless there are special circumstances that demand it, such as a couple of 1920's that I routinely service that have exceptionally weak hydraulic pumps, or the steering filter on 35 series and TL series tractors having priority valves that make self-priming of the pump difficult.
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
2019 JCB 457 (A60462)
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
2016 Kenworth T800 Tri-Axle Dump Truck (A59230)
2016 Kenworth T800...
