2001 tc40
/ 2001 tc40 #1
Greenthumbsback
Tc40 new holland
I have a tc 40 2001 gear drive that seems to be having transmission issues . When I go up an incline in 2 med (really any gear it almost slows to halt and I have to gun it. The engine does not loose power or any other signs it just feels sort of like the drive gears don’t have any power.
I was going to start with a hydraulic/trans fluid and filter change and go from there. Anyone else ever have this happens ? Thanks
By the way had to start a new account as I had not been here in years - life site goes fast but I’m back.
/ 2001 tc40 #2
Sounds like it's time for a new clutch to me.
Do you have any free play on the clutch pedal? It should have about 1". You can try and adjust the linkage but once it starts slipping, there isn't much hope in adjusting.
/ 2001 tc40 #5
Total sense..
Sorry I missed that in the original post..
That would definitely point to transmission problems, or whatever NH is calling it..
/ 2001 tc40 #6
If it is gear drive, sure does sound like a slipping clutch.
/ 2001 tc40 #7
Make sure your clutch is adjusted properly and the clutch arm is loose when released. Dont bother with changing the fluids at this point.
/ 2001 tc40 #8
It's a dry clutch. Sounds like it's slipping or worn out as said above.
What is the free play now?
2015 Mercedes-Benz C300 Sedan (A64557)
2015 Mercedes-Benz...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2015 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2015 CATERPILLAR...
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
Towable Air Compressor (A64553)
Towable Air...
