Hydraulic Filter change without changing fluid
/ Hydraulic Filter change without changing fluid #1
mrtwister
St. Charles, Ontario, Canada
Kioti DS 4510HS
I intend to swap out my old hydraulic filter for a new one without first draining the hydraulic fluid from the tractor...has anyone ever done this?...the fluid looks good however I feel the filter should at least be changed to eliminate any possible contaminants in the system.....is there an issue with hydro fluid gushing out when the old filter is removed before installing the new one or is the fluid simply resting at the bottom of the engine/transmission below filter level? :confused2: thanks...twister
/ Hydraulic Filter change without changing fluid #2
Just put a catch pan under it, it will not gush out, just replace with the new one as quick as possible. You will probably need to put about a 1/2 gallon back in with the liquid in the filter and what you loose.
/ Hydraulic Filter change without changing fluid #5
That's what is done on most by the manual. Mine is filters every 200 hours and fluid with filter every 400 hours. Just have the new filter ready and won't lose much.
/ Hydraulic Filter change without changing fluid #6
As others have said, I had to top off the tank with a little less than a gallon, I was slow!
Spin off, put new one on (make sure you put a little oil on gasket, or you will have a heck of time removing the next filter).
/ Hydraulic Filter change without changing fluid #7
On Kubotas, the trick is to put a shop vac on the fill port. The suction will prevent anything coming out when changing filters or doing work down there. Probably works on Kiotis too.
/ Hydraulic Filter change without changing fluid #8
Nice idea and will try the next time. Never thought of that. Thanks
/ Hydraulic Filter change without changing fluid #9
Did you end up doing this? I did mine, and it sure gushed out uncontrollably.... I managed to just screw on the new filter as fast as I could. I ended up losing at least a gallon of fluid if not more. Once again you can't trust the manual. Like you, I saw that they call for just changing the filters (both HST and Trans) but NOT the fluid. Yet, the fluid gushed out on me. Again, if they would have just field tested it more...... Anyway, that was my experience and I thought would it be that dang hard to just put a heavy duty petcock/close lever right above the filter to make it really easy to just change the filter?? Now I'm curious how it worked for you. I have an NX series, maybe they are different.
Thanks jabelding....I will do that...:thumbsup: ...twister
/ Hydraulic Filter change without changing fluid #10
Does work very well.
Buddy I work with had to change the suction line shut off valve on a plow truck, roughly 20 gallons of oil, 1 1/2" suction line. He shuts the valve which is right on the tank, takes off the suction line and doesn't lose too much oil as it's a downhill run to the pump at the front of the truck. Gets up, hooks up the vacuum, because it was a tight fit in the filler, he cleans it off and wraps a bunch of tape around the hose and filler to hold it in place.
He turns on the shop vac, gets back under the truck and starts to turn the fitting out of the tank, out it comes along with the oil....he put the hose on the wrong end of the vacuum, never laughed so hard when he came out, looked like a drowned rat.........Mike
/ Hydraulic Filter change without changing fluid #11
I am currently in the process of doing this on my L47... Oil cane gushing. When I purchased the filters at the parts counter of my Kubota dealership he said 土ou may want to grab a quart of UDT2 to top it off when done. Lol should have bought 2 gallons. The L47 has 2 hydraulic filters right next to each other. (Has separate HST filter opposite side of frame). Not a pleasant experience at all. Needs less to say I now have to wait till Monday to get more oil. SMFH... a Petcock or ball valve would be very helpful when they engineered this.
/ Hydraulic Filter change without changing fluid #12
Cavitation from a plugged (or turned off) filter or inlet will actually destroy a pump faster than a lot of dirty oil would. I'm sure not wanting liability on that is one if the reasons there isnt one.
The shop vac trick works great. You don't loose any noticable oil when the filters are off, even for several minutes.
/ Hydraulic Filter change without changing fluid #13
Understood. However I did use the shop vac on the 2nd hydraulic filter and only lost what was in the filter. I’m mad at myself for not having investigated sooner. I have to wait until Monday to pick up more oil to top it off. Lesson learned.
KUBOTA BT2914 - 23 1/2" PIN ON BUCKET (A64280)
KUBOTA BT2914 - 23...
2013 Dodge Charger Sedan (A61574)
2013 Dodge Charger...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
KUBOTA L4610D TRACTOR (A64280)
KUBOTA L4610D...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
