Hydraulic dovetail trailer questions
   / Hydraulic dovetail trailer questions #1
rustyshakelford
Texas
Deere 5100E/H260/MX15
I have a 25+5 tandem dual GN. Had it several years and has been great. I have ordered a new truck (F-450) and new tractor and mower (JD 5100E H260 and MX-15). With my current trailer I'll have to load the tractor way forward and have the loader over the neck. This will result in a bunch of pin weight and it'll be a very tight fit. Will also have to modify the ramps to stand up.
I have started thinning the herd of trailers and going to consolidate to one or two primary ones. Just sold a military trailer I don't use and need to sell an 18' bumper pull that I've never used due to it constantly being borrowed. I will also sell my current GN. I am looking a a tandem dual 12k/15k axles trailer with a hydraulic dovetail. I've been looking at them recently and they seem pretty slick.
Do any of y'all run them and how do you like them? I can get a loaded one with 12k axles and hyd landing gear for 15k but I'd rather save some more and go with the manual jacks. There's a new one semi-local with 10k axles for 11k but I'm afraid I'll be over on my weights and would like to have more than I need vs skirting the line
Brett
Is a tilt bed out of the question?
Where the whole thing tilts or like the back half? If just the back half, I would say yes it's out of the question because I wouldn't be able to fit the tractor and batwing on the tilted part before it came down. If it was the whole thing I think that it wood be pretty steep. This will be atleast a 36' long deck
Brett
   / Hydraulic dovetail trailer questions #4
Brett
We have a 44' semi pulled trailer and the back 32' tilt down to a 4' stationary section with an 8' upper deck. I don't think that I would ever even consider anything other than a tilt bed after using ours for the last 10 years.
   / Hydraulic dovetail trailer questions #5
Brett has to have a GN to fit his truck.
You are way beyond my experience in size Brett. Good question though!!! Curious to see what the trailer gurus come up with.
   / Hydraulic dovetail trailer questions #6
I understand that he needs a GN. I'm pretty sure that there are several manufacturers of them. Here is just one and they go up to 25K GVWR. ;)
This is what I'm talking about. Big Tex also makes one and I like the way the dovetail is a little better but these are the one I'm studying up on
Brett
Details
   / Hydraulic dovetail trailer questions #8
Nice!!!
Only concern I would have is the overhang behind the axles. Hafta be cautious about tail swing!!
Be sure to update us on your decision. Nice trailer!!!
   / Hydraulic dovetail trailer questions #9
We have a 30' GN with hyd dove at work. Ive helped load/unload it, and move it around the shop lot, its a nice piece of equipment. Dove tail is rated for 4k lbs. Tail swing is an issue, but not much worse than any other 30' trailer.
Loader Bucket (A50322)
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 Ford Escape S SUV (A50324)
2015 Ford Escape S...
Schulte FX1800 (A50121)
Schulte FX1800...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
